Golf 5
Aller à la page Précédente  1, 2, 3 ... 8, 9, 10 ... 22, 23, 24  Suivante
Poster un nouveau sujet   Répondre au sujet    vwspirit Index du Forum -> Golf 3 et plus
James
MessagePosté le: 19 Mai 2007 22:58    Sujet du message: Répondre en citant
MessagePosté le: 19 Mai 2007 23:03    Sujet du message: Répondre en citant
waouh, l' eclair!!!!!!stormmm!!!!
et cool la 5! Cool jantes dorees sur le noir assez sympa! Wink
nunog40
MessagePosté le: 19 Mai 2007 23:10    Sujet du message: Répondre en citant
si quelqu'un peut traduire!!!!!!!!
Well Volkswagen has pulled a fast one (literally) and decided to unveil a W12 powered, rear-wheel-drive, mid-engined GTI at the tuner/drunk/party fest in Austria known as Worthersee. We'll have more information, photos and video in coming weeks ahead. A full photo gallery is provided in the links below.
We also have a loosely translated version of the German press releaes below, but what we do know is this:
- VW claims a top speed of 202 mph
- 6.0l W12 12-cylinder twin-turbocharged engine mounted in the back seat of the GTI
- 650hp and 553 lb-ft. of torque (!)
- with the flared fenders that car sits over 6 feet wide and only 4.6 feet tall
- 19" wheels with 295 rear rubber and 235 front rubber
- the fenders are flared 3.15" at the rear
Press release coming next...
Wolfsburg, 17 May 2007 - Leaving conventions in its wake has always been at the very heart of the GTI. An icon over three decades, the GTI has lured over 1.67 million drivers with its siren song. To drive the GTI it to make a statement. Since 1982, GTI fans have gathered in Wörthersee, Austria. Thousands come to the five-day carnival at Wörthersee, and it is for them - the people who made the GTI a legend, that the GTI W12-650 show car was conceived.
More powerful than any Golf ever built, wider than any Golf crafted at Wolfsburg, faster than any of its iconic predecessors, the GTI W12-650 is seemingly fresh from the race course. A golf that packs in technology used for the Pace Car of the 24 hours of Le Mans. It is named after its heart: A W12 engine producing 650 horsepower. The GTI W12-650 is a show car, nothing more, nothing less, but it does show the enormous potential offered by the Golf platform.
3.7 seconds, 202 mph, 553 pound-feet
Its 6.0-liter twin-turbo engine is located lengthwise between the front seats, converting the traditional front-drive Golf into a classic mid-engined race car. A six-speed automatic gearbox feeds a maximum output of 553 pound-feet of torque to the rear axle. Such force catapults the GTI to 62mph in a scant 3.7 seconds. Stay on the accelerator, and the biturbo engine will carry the car to over 200 miles per hour, putting the GTI W12-650 in the rarefied air of dedicated exotic cars.
6.2 feet wide, 235-width tires in front, 295-width in rear
Under its 6.2-foot spread and 4.7' tall body, Volkswagen engineers and designers united technologies across the spectrum of Volkswagen AG for the first, and perhaps only, time. Each mechanical piece was originally conceived and designed by Volkswagen AG, showcasing the unequalled breadth of Volkswagen's technological prowess.
235-width tires on the front wheels are mounted to 19" gloss-turned "Detroit" GTI wheels, custom-made to fill out the deeply sculpted fender flares. At the rear, the gigantic 295-width tires extend much farther than standard GTIs to bring the GTI W12-650 a properly aggressive stance.
2.75" lower, 6.3" more broad
The wheels are tucked 2.75" further into the gigantic wheel arches, the shoulders of the fenders becoming coupe-like in their proportions. Says Klaus Bischoff, Director of Volkswagen Design: "In the back, the show car is wider by about 3.15" on each side. The standard model already has a strong shoulder line and arched flare, but, as with a sports car, we pulled the fenders more strongly outward."
He continues: "Our goal was clearly defined - despite the dramatic technical changes, the GTI W12-650 should remain clearly a classical GTI. The design of the Golf is like a fingerprint. If it smears, the character of the car is destroyed. We would not allow that to happen." To that end, as many parts as possible were carried over from production GTIs such as the headlamps, doors, hood and tail lamps.
C-Pillars as part of the engine air intake
"Our largest challenge," says Klaus Bischoff, "was to supply the six-liter mid-mounted engine enough air without diluting the silhouette of the GTI. Side inlets had to be used and optimized for breathing, and the aerodynamics of the car had to be reworked so that we could achieve sufficient cooling at the rear axle. We did not want to set an enormous tail wing on the car."
In both cases, a trick helped. Bischoff continues: "The strongest Golf design elements are the C-pillars, and it was exactly there that we needed the inlets for the engine air intakes. The C-pillars were redesigned by hand in such a way that we allowed the rear windows to cant slightly inward. So engine air is sucked in through a gap between the window glass and the C-pillar. Cooling is taken car of by an enormous radiator in front as well as by the ducts located in the flares." Each part of the revised bodywork appears at first sight to be a production GTI part, however they have been carefully designed to have increased functionality without sacrificing aesthetics.
Carbon fiber roof is a diffuser
Innovative and thoughtful construction of the bodies prevented the clean lines of the GTI W12-650 from being ruined by a roof-mounted wing. Says Klaus Bischoff: "This GTI moved the wing inward. The roof is part of an enormous diffuser, which provides sufficient down force on the rear axle. It is made of carbon fiber and forces air over and under the tail spoiler to obtain a perfect amount of pressure on the rear axle."
The bumpers of the show car show strong lines and clever design, as well. In the back, enormous exhaust openings mark the car as a GTI W12-650. Two chrome-plated dual pipes frame the exhaust opening in the rear. At the front, a red-line grille draws upon the heritage of the very first Golf GTI produced.
Interior with racing ambitions
Today's GTI drivers would feel at home inside the GTI W12-650. The leather and Alcantara seats are new. Three round gauges mounted in the center stack harkens memories of the Ur-GTI. Transparent "flip up" switch guards are used on the switches for functions such as the ESP override. To prevent mis-activation, the covers must first be flipped open with the index finger. Likewise the racing fire extinguisher integrated in place of the glove box reminds driver and passenger that the GTI W12-650 is a serious race car. For weight reasons, the door panels have been removed and replaces with lattices which allow a compete view of the door mechanics.
http://www.youtube.com/watch?v=rCvifZybyLg
http://www.volkswagen.de/vwcms_publish/vwcms/master_public/virtualmaster/de3/unternehmen/messe0/gti_treffen_woerthersee_2007.html
MessagePosté le: 20 Mai 2007 9:59    Sujet du message: Répondre en citant
Cool Cool Cool
ZEX
MessagePosté le: 20 Mai 2007 11:48    Sujet du message: Répondre en citant
Bah c'est un avion! Laughing
nunog40
MessagePosté le: 20 Mai 2007 11:56    Sujet du message: Répondre en citant
non..... VW Mr. Green
James
MessagePosté le: 20 Mai 2007 22:23    Sujet du message: Répondre en citant
En gros mis à part le bla bla
Elle à 650 chevaux du 0 à 100 en 3,7 et des pneus en 295 à l'arrière de large et du 235 à l'avant et c'est une des golf les plus puissantes jamais produites
marciano23
MessagePosté le: 21 Mai 2007 19:54    Sujet du message: Répondre en citant
Pour faire des rupteurs, elle doit aller pas mal! Laughing
ludo88
MessagePosté le: 21 Mai 2007 20:39    Sujet du message: Répondre en citant
Elle est vraiment superbe Shocked Shocked Monstrueux
MessagePosté le: 21 Mai 2007 22:48    Sujet du message: Répondre en citant
elle a quand meme des cote de clio v6, mais en mieux!!
mais un peu quand meme... Rolling Eyes Wink
MessagePosté le: 21 Mai 2007 22:56    Sujet du message: Répondre en citant
ouais, un tout petit peu!
je ne me suis même pas arreté quand on passé devant, faut dire que la One avec 74kils et la rallye avec 15'oookils étaient plus interessants Wink Shocked Love
MessagePosté le: 21 Mai 2007 22:57    Sujet du message: Répondre en citant
tu m' etonnes.... Wink
Nookie
MessagePosté le: 09 Juin 2007 9:39    Sujet du message: Répondre en citant
Un peu plus abordable Laughing
One Gls 1978!
Passat Tdi 2002!
MessagePosté le: 09 Juin 2007 9:42    Sujet du message: Répondre en citant
La j'aime bien ... Cool
MessagePosté le: 09 Juin 2007 12:45    Sujet du message: Répondre en citant
Oui moi aussi elle est vraiment splendide comme ca.... Cool Cool Cool
MessagePosté le: 09 Juin 2007 12:49    Sujet du message: Répondre en citant
+1, Cool
Greg IV
MessagePosté le: 09 Juin 2007 17:24    Sujet du message: Répondre en citant
+1 Cool Cool
Fuzz
MessagePosté le: 11 Juin 2007 21:35    Sujet du message: Répondre en citant
Y a pas mieux Cool
If only everything il life was a Reliable
nunog40
MessagePosté le: 22 Juin 2007 18:10    Sujet du message: Répondre en citant
********************800 de large max SVP********************
http://i11.photobucket.com/albums/a160/DC2ingB18C/DSC00017.jpg
http://lvs4.com/gallery/d/3802-2/IMG_4331_edit.jpg
http://lvs4.com/gallery/d/3792-2/IMG_4308_edit.jpg
http://img165.imageshack.us/img165/2607/adwork0mq.jpg
http://i77.photobucket.com/albums/j49/Kaiser84/ACFYPAiAai9d.jpg
http://i77.photobucket.com/albums/j49/Kaiser84/wsee2006-0101.jpg
http://img102.imageshack.us/img102/963/juanzs6.jpg
http://i61.photobucket.com/albums/h49/jimmyverbeeck/IMG_0356.jpg
http://members.cox.net/drivrswntd/jay3.jpg
James
MessagePosté le: 05 Juil 2007 12:16    Sujet du message: Répondre en citant
MessagePosté le: 05 Juil 2007 12:22    Sujet du message: Répondre en citant
Cool Shocked Cool Cool Cool Love
Greg IV
MessagePosté le: 05 Juil 2007 22:29    Sujet du message: Répondre en citant
Voilà l'aquisition d'un pote il y a quelques mois. Il vient de la rabaisser et lui a mis de jolies jantes millemiglia en 19 je crois et pour finir peint les spoilers avant et arrière.
Il sera sûrement présent le 15 juillet. Il était venu il y a deux ans à l'EPFL avec une R32 noir qui est sur le site. Mais je le laisserai se présenter sur le site si cela n'est pas déjà fait.
MessagePosté le: 06 Juil 2007 20:52    Sujet du message: Répondre en citant
Cool Cool
MessagePosté le: 08 Juil 2007 16:21    Sujet du message: Répondre en citant
Bien belle j'adore vraiment ce blanc.... Love Cool Cool
MessagePosté le: 08 Aoû 2007 17:15    Sujet du message: Répondre en citant
Poster un nouveau sujet   Répondre au sujet    vwspirit Index du Forum -> Golf 3 et plus Toutes les heures sont au format GMT + 1 Heure
Page 9 sur 24
